TwinTurbo.NET: Nissan 300ZX forum - so when I lower my tire pressure at the track...
Subject so when I lower my tire pressure at the track...
Posted by Z_PREPared on December 12, 2003 at 2:10 PM
  This message has been viewed 44 times.
In Reply To so? posted by genic on December 12, 2003 at 12:00 PM
Message although my contact area grows, it's actually the coefficient of friction that's increased due the the tires' increase in temperature from the lower inflation pressure?
As for the front, raising the tire pressure decreases the contact area, but what you're saying is really this also has no effect? The only effect I could see is to help transfer weight to the rear during launch?
Worked out some numbers for the Z.
55/45 weight distribution using 3480 lbs. or 1578.5 kg
front wheel @ 33 psi: 187.106 cm^2 = 22.5 cm x 8.316 cm
front wheel @ 40 psi: 154.35 cm^2 = 22.5 cm x 6.86 cm
TT rear wheel @ 36 psi: 140.324 cm^2 = 24.5 cm x 5.727 cm
TT rear wheel @ 25 psi: 202.026 cm^2 = 24.5 cm x 8.246 cm
NA rear wheel @ 36 psi: 140.324 cm^2 = 22.5 cm x 6.236 cm
NA rear wheel @ 25 psi: 202.026 cm^2 = 22.5 cm x 8.98 cm
click here to email me!
Memeber #124 of Capital Z of Texas and member ZCCA
My CarDomain page
